โOct-20-2021 02:20 PM
โNov-18-2021 06:06 PM
โNov-18-2021 03:33 PM
Bikeboy57 wrote:
Lets see if you get lucky. Many times those push on air line connections leak. Something that works sometimes is to remove the line from the fitting, and snip off 1/4 inch then reinsert. The nylon tubing gets a compression ring in it over time. If the internals of the valve are leaking this wont help. How many wires are connected to the switch. BTW, it is not a switch but an electrically controlled pneumatic actuator
โNov-18-2021 01:29 PM
โNov-18-2021 02:40 AM
Cindy and Steve wrote:larry cad wrote:
By the way, this switch, available on Ebay, is likely to work on this application, and for only $59 plus shipping.
4 way, 2 position, air switch.
The ports and slides are slightly different, but pretty sure this one can be made to work, but we have more studying to do.
This is the same switch that MountainAir05 suggested also.
Hi. Sorry for the slow response. Been working away for a long time. So this product you showed looks promising. I assume there are some threaded things that go into those holes that will receive my airlines?
โNov-17-2021 02:59 PM
โOct-27-2021 04:56 AM
โOct-27-2021 04:51 AM
โOct-26-2021 04:53 PM
Here is that sticker. I had to peel it off the other day to open the switch so I just stuck it on the dashboard. LOL.
โOct-26-2021 02:48 PM
โOct-26-2021 03:28 AM
โOct-26-2021 03:22 AM
โOct-25-2021 07:33 PM
Cindy and Steve wrote:MountainAir05 wrote:
Does your step cover make the step inside the Rv or does it just slide out straight and cover the hole.
This is where you get 12 volt actuators when needed.
https://www.firgelliauto.com/
this is the link for the info about maybe your step cover.
https://www.irv2.com/forums/f103/step-cover-lift-motor-114580.html
The cover is also the steps. They donโt slide back and forth as some do, they raise up and down. Sometimes I can force it up by hand and peek under it. There are absolutely no electrical wires at all. Just an air operated cylinder. The piece Iโve shown in the picture is the backside. The front is just a little up/down dial that seems to direct air to the cylinder when turned to the up position.
โOct-25-2021 07:12 PM
โOct-25-2021 07:09 PM
