rgatijnet1 wrote:
To the original question, regarding the Allison 1000MH transmission. ONLY TES295 approved transmission fluids are recommended. D3M fluid is NOT TES295 approved. D3M fluid specs
So the choice is yours, use a non-approved fluid or use what the Allison engineers recommend.
TRANSYND (TES 295) is obviously the better/ and
recommended choice for use in Allison Transmissions.
Most Allison's in use now come with or have been refilled with TRANSYND, however those remaining transmissions using DEXRON III equivalent fluids, licensed by Allison as meeting their TES 389 are using an
approved transmission fluid.
As stated on the Allison website: "TES 389™ fluids may be used in traditional on-highway products but do not provide the same drain intervals or filter change intervals as Allison Approved TES 295®"
Your link to Petro-Canada D3M fluid indicates it is TES389 licensed and therefore is an approved Allison fluid..
edit..I should add that not all D3M fluids are licensed as meeting Allison's TES389..
