Boogiemachine
Apr 22, 2020Explorer
Alternator not charging Batteries
Hey guys well figured out the voltage problem on the RV now I'm having a problem with alternator not charging the batteries. 96 Southwind with 7.5 E350 engine.
So Batteries are showing 12.3 V when the RV is running and 14.3 at the alternator. I traced the wires down to the Starter switch and checked voltage at the each lug and discovered that the second lug to the battery side isn't at 14V its at 12. Question is its definatly a solenoid can I introduce 12V to the controller lug to see if the mechanism is bad or does it take less then 12v. I also discovered the Fuse and fuse block line for the Starter Switch Coil was dead.
Any thoughts? I'm thinking it might be a computer issue. Also all battery terminals have been cleaned/relugged and all the grounds to the chassis were cleaned up
![](https://i.imgur.com/srV8hArl.jpg)
[img]
[/img]
[img]
