- Dutch_12078Explorer III agree it operates properly in any position, but having it oriented with the bowl down makes it a lot easier to twist the bowl off for cleaning without spilling water in the bay.
- wa8yxmExplorer IIIQuestion: Is it leaking?
Yes: you have a problem
NO: you will not have a problem so long as you remember to winterize it. by opening it up and letting it drain onto a towel if that is you winterize. - midnightsadieExplorer IImakes no difference even upside down.
- Executive45Explorer IIIThe filter works off pressure not gravity. It's fine....Dennis
- MURPHY55347ExplorerIt makes no difference what position it is in.
- Dutch_12078Explorer IITry adding or removing thread tape until it snugs up where you want it.
- gb76087Explorer
That is a new one. The filter assembly will not screw on enough to allow the filter to sit vertically. - F-TROUPExplorerBuy a new one standard size and $4-5
About Motorhome Group
38,709 PostsLatest Activity: Mar 09, 2025
