kdk wrote:
Is there a better over the air antenna than the crank up bat wing? Thinking about a replacement and wondering if any body has better luck with something different that is not directional.
Thanks in advance;kdk
There are two types of replies you can get: I read lab reports (prepared by another forum member) and others will tell you what they feel.. Problem is there are in fact two answers
Antennas come in basically 3 types
First: to properly understand what I am about to type you need either a smart phone app (Antenna Helper Free) or a web page (Antenna pointer pages) and in the latter your precise location (lat and long gps style)
Antenna types:
Omin-directional.. It is possible to park so that the Antenna apps/pages show the towers in a circle around you Say you are "Wally Docking" at the Tel-12 mall in Southfield, MI., that would be such a place. Of course when you are that close to the towers a paper clip might well do the job. (used to live 5 miles from there)
Otherwise I consider these fluing saucer jobs to be JUNK.
The Jack (from king controls) this is a wide beam antenna, if the stations are covering say a 45 degree arc, (Still fairly close in) this might well be better.
Winegard Batwing, un-modified (Sensar II or III) this is a very good VHF antenna, roughly 50-60 mile rated. Not so good on UHF (perhaps half that).
Winegard Batwing (Sensar II or III) with Wingman (or Sensar IV which comes with the Wingman) this fixes the UHF problem, so it's not 50-60 mile rated on all bands (There are 3 bands). This is the best RV TV antenna if you are some distanc from teh tower.. But it is a tight beam (meaning if towers are all about you you have to re-aim a lot.
Now: To improve that even more....
On the standard Sensar line (All 3 of the ones listed above 2,3 and 4) the indoor module is normally a wall plate with a switch, light, 12 volt outlet and antenna connection (3 more connections plus 12 volt connections on the back) many call this "The booster". it is not, it is the power supply for the booster which is in the antenna where it belongs (I do know why but .. Well, lots of typing).
The alternate indoor module is a Box of Many buttons (matrix switch) which they no longer make.
These devices provide power to the antenna's built in booster, they also select between park cable (or one other source) and OTA.
Winegard makes an alternate wall plate. The SENSAR PRO (I have one), this 100 dollar upgrade made a BIG and I mean BIG difference in the number of stations I can pick up in one of my favorite campgrounds,, Did not do bad in a few others.
Recommendation: Sensar IV with Sensar Pro for best long distance results, Be sure to read the instructions on the Sensar pro.
