- KID2TEXASExplorerIf you already have the bypass on then I would go ahead and drain it out and spray some water back up in there and flush out a couple times and then just leave the rod out or cap off or wait till spring.
- Hemi_RTExplorerYes
- MJD202Explorerok, thanks.
- midnightsadieExplorer IIwon,t hurt a thing.
- TucsonJimExplorer III did the same thing last year. No problem at all if you leave it in. Most folks just drain the water heater instead of pumping all that antifreeze into it.
- wolfe10ExplorerOnly real question-- was the water heater full (of potable water) when you started adding potable antifreeze? If so, it could be too diluted to properly protect your system.
Said another way 6-10 gallons of water added to the potable antifreeze changes the freeze point substantially. - Oklahoma_DanExplorer
This guy is right. If you have by-pass valves for winterization then you should go ahead and pull your anode rod or plug out of the water heater to drain. Otherwise water heater would eventually freeze up because there isn't enough anti=freeze content in that water heater to protect it. - AJRExplorerGetting the antifreeze out of the tank is going to be a pain at any time. Don’t ask how I know. I would say the sooner the better. As there is stuff in the bottom of the tank that could absorb the antifreeze I think. What a pain…..
About Motorhome Group
38,705 PostsLatest Activity: Jan 20, 2025
