dbro60's avatar
dbro60
Antifreeze in Water heater.
Need some help. I have Coachmen Concord and just drain all the tanks, drained water heater, left plug out. Turned the bypass valve off. Opened all faucets, blew lines with air and just to be safe rigged a hose to the water pump and pumped antifreeze through lines until it came out of faucets. All is good but I go out side and see antifreeze coming out of the water heater drain plug opening? Should it not have gone there since I "bypassed" it? I just left plug out. Any problems?
Thanks,
Dave
  • skipnchar wrote:
    My advice is put the plug back in to protect threads over the winter months. Antifreeze will not harm the water heater but you may have a leaking check valve. This should prevent back filing of the heater.
    As a point of clarification, RV antifreeze is very corrosive to anodes, so if you have an anode, don't get antifreeze on it. (information from one of the water heater manufacturers websites)
  • Guys, Thanks for your replys. I had two valves. Got it all taken care og.
    Thanks, Again,
    Dave
  • Old-Biscuit wrote:
    Improper valving OR bad check valve.
    Probably bad check valve.........common problem.
    Remove check valve and install another valve.
    I have one of these in a baggy zip tied to the check valve, just waiting till the valve needs replacing. I will go from a 1 valve bypass to a 2 valve bypass.
  • Just make sure and rinse it real well when you dewinterize. Macktee
  • What kind of WH system do you have..........1 valve, 2 valve or 3 valve?
    1 valve.......3 way valve that controls water to WH cold inlet. Turn it 90 degrees it 'bypasses' WH cold inlet, ties into WH Hot outlet line and a check valve in Hot outlet stops water from backflowing into WH.
    If so....BAD CHECK VALVE
    2 valve.......both valves have to be set to 'bypass' position otherwise flow to WH is not stopped
    3 valve.....cold inlet and hot outlet valves have to be CLOSED and 'bypass' valve as to be OPENED
    Here is another post....same problem.....with pictures.....LINK
  • My advice is put the plug back in to protect threads over the winter months. Antifreeze will not harm the water heater but you may have a leaking check valve. This should prevent back filing of the heater.
  • dbro60 wrote:
    turned the bypass valve off.
    Sounds like you should have turned the bypass valve ON.
