Anyone interested in 83 Pace Arrow Tear down and Rebuild?
fulltimin
Started to look into some water damage in the kitchen of our 83 Pace Arrow. The more I looked, the more I found. I have some pics of the damage so far. Anyone interested in following a rebuild thread?
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
8,452 REPLIES 8,452
fulltimin
Hope everyone is having a GREAT Holiday Weekend! ๐Ÿ™‚
fulltimin
Here is a slight preview of what's coming on the counter top and the front of the shelves.
Did a bunch of sanding and cutting today, and got to the point where I could kind of hold these in place long enough to take a picture.
fulltimin
Brob wrote:
The roof is getting closer!
I put a 2 part liquid EPDM over my aluminum roof 2 years ago. It took me several days of prep work to get the roof where I wanted it before the new coating was installed. I barely slept the night before I was so excited and apprehensive at the same time. Once it was complete, I was so relieved.
Prep work always seems to take forever........ Then the final work gets done, and it's like, Wow! Look what I did today! Lol.
I'll be glad when the roof is glued down. Several other large projects have been like that. They turned out to be easier that what I was dreading it was going to be like.
Hopefully, this will be another one of them.
Brob
fulltimin
So, I need to update the spreadsheet.
The TPO adhesive cost me an additional $174.90. The Mixer was $20.12. The Lacquer thinner was another $18.17. All prices include state sales tax. (Can't forget the governor).
All of that amounted to $213.19. That now brings our new total up to..... (drum roll)....
$9,649.56
fulltimin
I also called the roofing distributor and picked up a 5 gallon pail of adhesive. Turns out it is a Low-Voc version used for EPDM and/or TPO roofing.
It is a contact adhesive, so I guess I'll have to test it out on a smaller piece to see if it can be moved at all after putting the 2 together. Both surfaces get coated with the adhesive, allowed to dry a little bit, before putting them together.
To go with that, I needed something to stir it up, and make sure it is mixed properly. Enter a long drill powered mixing device.
fulltimin
When the going gets tough, the tough go shopping! OR, when the weather is lousy, it's a good time to go shopping.
We had been waiting for a lousy weather day to pick up some groceries, and a few other things, so we had a wonderfully, lousy weather day today, so off we went!
I am almost out of Lacquer thinner, so that was first on the list.
fulltimin
Here are a couple of closer pictures to be able to see the difference.
That's all for tonight, Capt'n.
fulltimin
After getting the shelves in place, I decided to sand some of the black walnut that will get used for the shelf face frames. No pic for that.
I did, however, also give a quick sanding and put some lacquer on the cedar boards that I got from Lowes, and planed them down.
Here you can see the difference between having some oil based lacquer applied, and the areas on the left, where there is no lacquer.
Yes, all 3 of those are cedar.
fulltimin
Of course, we can't forget the single screw going into the ceiling, into the hidden plywood.
fulltimin
Just like the passenger side, this is screwed to the bath wall, as well as the shelves having a piece screwed to the wall and back of the shelf as well.
Also glued and screwed on the opposite end - towards the front of the coach.
fulltimin
Here are the shelves on the drivers side, finally screwed and glued to the wall. Wahoo!
fulltimin
I was working on the drivers side shelving today. During the process I was thinking ......
What ya gonna do, what ya gonna do, what ya gonna do, when ya can't use a screw? I decided to give it a wedgie!...
Say what?????
This was at a spot that I could not use a screw to draw the bottom of the shelf end against the wall. Soooooo,,,,
I clamped a block of wood on the counter top, and proceeded to use a piece of wood that was tapered, (black arrow), and lightly tapped the wedge in until the back of the shelf end was tightly against the wall, with the adhesive between the two, (red arrow). Now, we wait....
fulltimin
This is a pic of underneath the top shelf, before I cleaned up the adhesive squeeze out. You can see there is adhesive between the strip and the wall, and there is also adhesive between the shelf and the strip, as indicated by the arrows.
That means, those shelves should be nice and secure to the wall.
fulltimin
Under the top shelf are a pair of screws that also are screwed into another piece of 1/2" plywood inside the wall.
