- flyfishing48ExplorerThank you everyone for the info. Lots to learn about for someone contemplating a switch to class A.
- Big_KatunaExplorer IIAnother satisfied Readybrute user since 2004.
Lifetime warranty. One of my actuators broke a few months back. Sent it in and they completely rebuilt and replaced all moving parts and painted it. Looks like new.
$0.00. Even paid return shipping. - Dutch_12078Explorer IIWe've been using a ReadyBrute Elite tow bar with an integrated ReadyBrake system for about 10 years so far, and have been very happy with it. The ReadyBrake system is available as a stand alone unit that works with any tow bar, and is simple mechanical system with few failure points and no electronics. Since it's a surge system, it only applies the amount of braking needed to unload the weight of the toad from the RV when stopping.
www.readybrake.com - Jayco-noslideExplorerI use the Blue Ox; latest newest one, I think. Tow a Focus behind a Class C. Really like the smoothness with which it brakes. No jerking or uneven braking. Also, it's wirelessly connected to the MH. It is expensive and not real quick to hook up but then I have nothing to compare it to. Still, I would recommend it.
- HikerdogsExplorerWe've been using a Roadmaster Brakemaster 9060 to tow our 2004 Jeep Wrangler (tJ) behind our 2013 Winnebago Adventurer 32H.
https://www.roadmasterinc.com/products/braking/brakemaster/brake_m.html
We used the same system to tow the Jeep behind our 2001 Winnebafo Adventurer 32V. We chose it because it provides proportional braking and the only part to install or remove is an air cylinder in the Jeep.
It's been an excellent system for our application. The only downside is the time it takes do do the initial installation. If you have the system professinally installed I would guess it would take between 8 and 10 hours to do both the Jeep and the motorhome. In our case I spent 3 days doing the install. Rather than run the wires along side the existiong wiring harnesses I opened each of them and ran the wires along side the others inside the harnesses. The installation is seamless and there are no exposed wires anywhere in or under the coach or in or under the Jeep. - AirdaileExplorer
- flyfishing48ExplorerWe are leaning towards a Jeep Wrangler behind a Tiffin Alegro Breeze 33BR or possibly a Red.
- way2rollNavigator IIAlso, what sort of tow bars do you have? I use the ready brut elite with integrated mechanical braking system. Nothing to remove each time and no electrics or air system to fail as it's all mechanical.
- wolfe10ExplorerMuch of the answer will depend on WHAT toad you have.
Some very good systems only fit on certain makes/models because of clearance issues.
Another issue is how often you change toads. If keeping it for a long time, installing a permanently mounted system makes a lot more sense than if you change toads frequently.
Let us know both what toad and what coach you will be using the braking system on and we can give much better advice.
About Motorhome Group
38,705 PostsLatest Activity: Jan 24, 2025
