EndlesssummerExplorerAug 18, 2023Auxiliary Start Solenoid ReplacementA while back I needed to use the auxiliary start switch under the dash. The chassis battery was failing. I looked at the old solenoid in the battery compartment and it was hot to touch. So I replace...Show More
enblethenNomadAug 18, 2023This is relay is the style of many relays used.The metal case dissipates heat.
Related ContentAUXILiARY FUEL TANKLeveling jack solenoid replacementAuxiliary Fuel Tank optionsAuxiliary gas tankauxiliary fuel tank
