Your_PalExplorerSep 28, 2015Bad converter?How do I know if my converter is bad? I has a slight buzzing sound coming from it. The fan is spinning. My slide comes in and out slowly as well. I want to clean the battery cables. They look fine b...Show More
sclarkExplorerSep 28, 2015if you have a volt meter you could check the voltage at the battery terminals. Should be at least 13.4 if your converter is working. Good luck.
Related ContentBad converter?Theft: the bad, the bad, and the really badBad gas ?Convert to tankless?Bad Slideout Squeel
