Banging noise
frmAloha
When hooked to electricity, I've begun hearing a banging noise from the distribution center. It stops if I turn on lights that work off the battery or while the furnace is running. Asked about it when the rig was in for service, but was dismissed as unimportant. Any ideas about what's causing this? And should I be concerned?
Oregon Native
Retired w/
2000 31' SurfSide
Class A
6 REPLIES 6
frmAloha
I appreciate all of your thoughts. They give me ideas to pursue with my service center.
In case it helps, my rig is 30 amp, and the breaker panel is in a different area of the coach. This noise does sound similar to a something snapping on and off, but it comes from a panel that contains numerous fuses not breakers. The noise is intermittent. Could it have anything to do with a park's voltage?
Oregon Native
Retired w/
2000 31' SurfSide
Class A
harley-dave
TucsonJim wrote:
My first guess would be the cooling fan is going bad.
yep, I replaced one that did this very thing.
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
MountainAir05
Sounds like the screw lugs for the wires in the transfer switch and breaker panel are not tight.
TucsonJim
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
enblethen
Your service center shrugged you of and should not have. Any strange noises should be investigated.
Do you have an energy management system? The noise you hear could be relays in it dropping or picking up.
What type of electric service does the rig have 30 or 50 amp? Does it happen all the time or just connected to one type of service or another?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rgatijnet1
I have heard electrical transfer switches that hum from time to time. Sometimes this could be fairly loud but I would not describe the noise as banging.
