AikenRacer's avatar
AikenRacer
Basement floor replacement under fresh water tank
The floor underneath my fresh water tank was rotten. Just demo'd it. Pulled out the water tank. Plan is to clean up the metal support structure, put in a new floor and install the water tank back. The replacement floor will be about 4x8' with a cut out for the dump valves. Couple of concerns..
1) What do I use for the flooring? Need protection from road hazards on bottom and it needs to be strong enough to support a 6' x 4' vinyl water tank (there are 2 metal cross braces). Thinking about a sheet of marine plywood.
2) There was no drain anywhere on the old floor. Should there be one and if so, what kind?
Any comments welcome.
Thanks!
