garyemunson wrote:
"Why would anyone need a bath and a half in a motor home?"
When you both order Mexican???
Fact: When you travel and you want a drink of water you have two choices. Bottled or "Tap".
Bottled water .. Well lots of concerns there but I know a restruant that sells Dasani, 16.9 ounces for $1.69.. You think gas or Diesel is expensive folks that is 12.80 per GALLON and it is WATER..
I drink tap. so did wife
When I was summering this year in MI I drank nearly exclusively from one set of wells (I only filled up at one park) and I filled just before heading south. Left MI on Halloween, did not run out (80 gallons) Till Thanksgiving morning. Took on my first tank of SC water on Thanksgiving day... And went through all 80 gallons in just a week.
WHY? Well. to put it simply.... The change in water had shall we say "After effects" and when those after effects hit, as they will likely again come end of April when I go back to Michigan.
"How long "A minute" is depends on which side of the door you are on"
Is a very true statement
A bath and a half model means 2 holes, no waiting.
