Dread_Pirate
Apr 22, 2014Explorer
Battery Control Center Fusible Link Mod Installed
My 1998 Southwind 35P has a CB115 rev a BCC. It looks like someone installed a fusible link (a wire that is designed to melt and separate with continued high current)between P13 connector on the electronic circuit board and the red wire that I assume goes to the Chassis Battery Disconnect. This seems to burn out occasionally and sometimes for no apparent cause. It has also burned out while working the hydraulic jacks. Does anyone know if this is supposed to be a fusible link, or should it just be a #10 wire?
