Gruu's avatar
Gruu
Battery Disconnect switch.
I have a 1999 Rexhall Rexair. The battery disconnect switch for the coach batteries will not reconnect the batteries. I have replaced the switch to no avail. When pressing the switch, the light comes on and goes out again as soon as I release the switch. The batteries are fully charged and they are only 1 month old. I am at a loss, any suggestions?
  • The disconnect solenoids are usually (always?) the latching type so that no voltage/power is required except when switching. There are two signal terminals and reversing the polarity (swapping plus and minus) switches the solenoid from one state to the other. The solenoid may need to be replaced. I would put a voltmeter on the two terminals and watch while someone presses and holds the switch one way and then the other. If the voltage is there and reverses polarity but the solenoid does not activate then you probably need to replace it.
  • That switch controls Big Relays, picture in link. This is just a picture so you can look for it. https://www.youtube.com/watch?v=UGxJs5XaSWY
    Check near the battery or fuse panels. Mine are located in the front. Others in different places. Wrap them with a mallet and try the switch inside again. Works best with two people, one pushes the inside switch and the other one listens to see which one is controlled by that switch.
  • What is the voltage on house batteries?
    The switch operates a relay, that with low voltage will not engage.
    At least that is standard set up. Can you access the relay and take picture?
