Mar-21-2021 05:09 PM
Mar-25-2021 06:27 PM
Mar-25-2021 12:06 PM
Bud
USAF Retired
Pace Arrow
Mar-25-2021 11:12 AM
Mar-24-2021 11:01 PM
pnichols wrote:
Now ... what has happened twice in 15 years regarding our current motorhome's batteries getting charged by the Ford alternator ... is this: The 12V solenoid that connects the engine alternator to the coach batteries whenever the ignition key is turned on has failed, such that we arrived at our destination with coach batteries that did not get charged by the alternator.
This above situation was probably due to corroded contacts of the solenoid - because I could still hear the failed solenoid engaging when I would turn on the ignition key. I now have an after-market heavy duty 12V solenoid with silver plated contacts inter-connecting the engine alternator and coach battery bank.
Mar-23-2021 08:44 AM
bobndot wrote:
Phil, good tip on cleaning the solenoid contacts, i'll put that on my list. Tnx !
Mar-23-2021 03:43 AM
time2roll wrote:
^^^^ perfect example on how all can be updated to suit your needs ^^^^^
Mar-22-2021 02:54 PM
Mar-22-2021 02:37 PM
Mar-22-2021 12:35 PM
Mar-22-2021 11:51 AM
time2roll wrote:bobndot wrote:Yes and will usually soon get corrected.Dealer is not always correctSame applies here. :B
Dealer's word just stands in the darkness.
Answers here also have no profit motive.
Mar-22-2021 10:42 AM
coolmom42 wrote:
I have a 2014 Coachmen 21QB on a Chevy 4500 chassis, with an Onan 4KW generator.
*Does the generator have its own starting battery? If so, how is this battery charged? Or does the generator crank off the chassis battery? (I'm assuming it doesn't crank off the house battery, as that would kind of defeat the point of having a generator.)
No the gen. does not have it's own battery. It uses the house battery(s)to start. If you see a battery under the chassis most likely mounted on the left-side frame rail somewhat near the generator, that is a GM option called "isolated 2nd battery." I've posted on it before in this forum.
*Does the generator charge the chassis battery?
No.
*Does the chassis alternator charge the house battery? If so, how well?
Yes. It does it so well that if the house batteries are already or mostly fully charged, on long drives (I drive 10-12+hours some days) I will disconnect the charge function (solenoid) from the chassis alternator as to not over-charge the batts. My alternator puts out 14+ volts much of the time. The GM chassis with the rv package (which coachmen usually seems to have) have a higher amperage alternator as well.
*Does the battery isolator switch completely isolate the house battery and chassis battery from each other?
I don't have a battery isolator switch between house and chassis batteries. If by chance you meant the house battery disconnect (off) rotary switch, the alternator will still charge the house batteries with that switch off.
*Does the converter charge the chassis battery when the RV is plugged into shore power?
No.
*On the side of the engine compartment, there is a 200 amp fuse. What is this for?
Do not know. I do not recall seeing a 200amp fuse, not sure if I have one. That's a pretty hefty fuse.
Mar-22-2021 10:10 AM
Almost every RV is set up to allow the chassis alternator to charge the house battery. (it's a beautiful thing that comes almost for free).
I have a 2015 Thor Majestic 28a...In my experience, the chassis alternator does a great job charging the house batteries. I have a battery monitor on my house battery bank. When the house batteries are at ~50%, I have seen my chassis alternator pumping 50+ amps into my house batteries when the engine is running (even just idling).
-Chris
Mar-22-2021 10:05 AM
Mar-22-2021 10:00 AM
Mar-22-2021 09:42 AM
