pianotuna wrote:
That's great news! Now adjust the voltage set points for float down, if possible.
If you plan to boondock or want the best life span from the batteries add a modest solar charging system. Your batteries will thank you.
Beaver Thunder wrote:
The Xantrex does have a temp sensor that has been installed correctly.
There's no adjustment in the inverter that I saw in the manual but there is in the magnum combiner, I have no idea what to set it at, any ideas? The coach does have a solar panel and best I can tell it charges but honestly haven't played with it yet (I store under a carport). Thanks for your help.
