ECones
Sep 06, 2015Explorer
Battery problem
Our battery in the RV went down this weekend and wouldn't stay up while running down the road.
I checked it once back home, and with the switch in "Store", the battery puts out about 8.5 volts whether plugged into 30 amp or not. In "Use" with the truck engine running it checks about 12.5 volts across the terminals, and with it plugged into 30 amp, and the battery switch in "Use" it reads 13 volts across the terminals. It seems to be charging.
Since it went down while driving down the road with the switch in "Use", I'm thinking the battery is done for, but I'd sure like other opinions.
Second part of the question:
If it does need a battery, this RV is only 6 months old. Should the dealer replace it under warranty?
