You might want to check the specs on your power supply. It may have a 'charge maintenance' mode/level, that does the job of the tenders.
I replaced the power supply in my old 2000, when it went out. The now supply has the mode in it already.
Took the double ended cigar/power supply jumper from my portable air pump. Plugged it into the dashboard, and the socket in the 'house'. I just leave the coach plugged in all winter. Batteries (all three) stay charged, and the computer doesn't loose it's mind either. Win Win.
IIRC the supply was only $175 or so 'delivered'. But that's been a couple years ago now... The better news is that I haven't had to refill the batteries since, so they're not being overcharged.
