RRTom
Oct 08, 2020Explorer
Battery questions
I just had the house batteries replaced with AGM's. I checked the built in "battery control" and voltage was reading 8.85. This was one week after install. I started the generator to exercise it, the ...
time2roll wrote:RRTom wrote:Yes, the batteries like this float voltage to be on for maintenance while the RV is not in use.
OK, I left the 50 amp plugged in overnight. The reading this morning is 13.4. Is that in the proper range?
This should be described in the battery charging and maintenance specifications. If you post the exact batteries this can be confirmed.
Generally the PD9270 is good for all flooded and AGM batteries.
