- fordman17ExplorerThanks,i check it ever couple months and when I return from a trip if it's going to be parked a while.
- gboppExplorerEvery 4 to 6 weeks. It's much cheaper to check the batteries than it is to replace them.
- lj2654ExplorerI check mine about once a month and it works fine. Only have to add small amounts even then....
- TucsonJimExplorer IIMy latest batteries are 14 months old. I check them about every three months. I've only had to add a little water about two months ago.
- rvtenExplorerAt least once a month. Would say depends on how heavy a load you put on your batts. Depends on how much charging they will need and water.
- hmknightncExplorerBefore leaving on a trip and when put back in storage after a trip
- DakzukiExplorer
fordman17 wrote:
How often do most of you really check the battery water level ?
Open caps, look inside....except.
I have done that for the last time on the coach batteries. They are coming out. I am cleaning all the******out, repainting the metal and.....
I am stepping up to AGMs.
Solar is next.
About Motorhome Group
38,707 PostsLatest Activity: Feb 28, 2025
