Don_and_Eileen's avatar
Apr 26, 2014
Brake Light Access
Those of you who might be familiar with a 2004 38-foot Tiffin Allegro Bus may be able to help me with a problem.
I have a driver's side brake light which is "out." I cannot find the "way in" to change the bulb. I see no screws on the outside; the inside (from inside the engine compartment) is pretty well blocked by a vertical 10-or so inch vent tube running just to the inside of the light.
From what I can see, there doesn't seem to be access to the bulb from the backside either.
If you've had experience in gaining access to this bulb, I'd like to hear about your experience.
Thanks.
Don
  • I spoke with Tiffin Service yesterday; got some advice and the problem fixed. I was into it for better than 2 hours, though. What should be a simple fix is anything but -- a design fiasco.
    The access must be accomplished through the engine compartment.
    First you must remove one end of the 8" vent tube -- I removed the bottom end. The tube is removed from its "home" by some (rather severe) yanking.
    There are two bolts on the mid- and top- far side of the taillight assembly. The top one is easy to miss in this cramped compartment. The top bolt has barely enough room for a socket; the mid-level one needs an open end (7/16) to remove it. Mostly, because of the size of the area and the location of the bolts, this is done "blind" - by feel or touch -- as both arm and head do not fit in this space.
    Finally, there is small "set screw" mid-level on the near assemble wall. It nestles behind some wiring for the taillights and is not immediately obvious.
    Once the tail light assembly is free from the m/h body, there are 3 more screws in the back of the assembly to allow access to the bulbs.
    Once I got to this point and grasped the offending bulb, it suddenly lighted -- apparently the result of dirty contacts. I sprayed the receptacle and bulb contacts and achieved a solid light.
    Re-assembling presents its own challenges,
    After replacing the 3 screws to re-assemble the taillight assembly, I tackled trying to replace the 2 bolts and set screw. Holding the assembly in place AND reading into the engine compartment simultaneously proved impossible. I enlisted the aid of my wife to hold while I attempted to "nest" the bolts into their proper location. I kept missing the threaded hole trying to feel "blind" where it should go.
    The setscrew is easier - although still done "blind."
    Replacing the fabric of the vent tube over the air cleaner was another time consuming chore. The fabric kept folding under itself and inside the air cleaner rim. But with time and persistence I eventually got it.
    It does seem like there is a better solution to access to the tail light bulbs.
    Tiffin?
    Don
  • A lot of these lens housings pop out and it all comes out in your hands and snaps back in...that's the way it is with my HR..you have to pry out very carefully so not to damage caps or housing..then snap back in..with these fiberglas caps....it's easy to do damage so just be easy on it.
