Sherribre
Jul 21, 2024Explorer
Brakes
Traveling through Yellowstone did not down shift around inclined area. Air brake alarm went off. Will the system start again. Ty. Stranded
Fround the problem it is a air leak in the line
The alarm means your primary air system pressure has dropped below a set-point, likely 60 PSI, due to your leak. If it is a hose/line you can "cap-off" upstream of the leak it might be enough of a band-aid to get you to a place where you can fix it properly. I wouldn't recommend doing it if the hose in question leads to a brake, but if it is going to say an air-spring, you can stop the leak so your coach can get up to proper pressure and limp along slowly to the nearest truck shop, etc. I carry an assortment of 3/8", 1/2", and 5/8" DOT caps and plugs (NPT and quick connect) just for this reason. Good luck and stay safe!
