โDec-10-2003 04:42 AM
โJan-06-2008 07:36 AM
Badeye wrote:
After some conversation with Diesel-Lover and others on this forum I thought I would try to start a thread concerning breakdowns on the road. We try to prevent this by good maintenance and driving reasonably but it can still happen. As I observed in a previous post, on a roughly 350 mile northbound drive on I-75 I saw 4 class A MH broken down. All were southbound.
If we should have a breakdown and would post the following information on this thread it could be a resource and reminder for others.
RV particulars:
Driveline (Engine, Transmission):
Miles:
Year:
Break Down Description: (You can add any description of the problem here that you think would help others in understanding the situation and problem.)
Symptoms:
Effect:
Cause:
Outcome:
This is the type of information that is recorded in the aircraft industry and other maintenance activities to track failure trends. It will take a while before we see a lot of value in this. If it continues for a time and sufficient data is available, I will analyze the data and put it into a form that I can send by email to any interested parties. I would suspect that an initial report could be done in about three months or when we have about 100 to 150 cases.
What do you think?
โJan-02-2008 08:04 PM
โDec-31-2007 02:58 PM
Norm F
โDec-30-2007 07:25 PM
โDec-30-2007 03:31 PM
โDec-30-2007 08:22 AM
pkunk wrote:metalmangler wrote:"...Chassis battery's runs down.
Outcome: Replace battery's (less than a year old, Interstate batterys, would not hold a charge.)"
Batteries less than a year old not holding a charge? That's a symptom, not a cause, even if it caused something else in turn. You'll be doing this in about a year (or less) again, unless you can isolate & correct what causes it.
I stopped buying interstate batteries because they die within a year.
Want a good RV battery? look into Optima.
โDec-28-2007 06:40 PM
โDec-21-2007 05:50 AM
โDec-15-2007 12:59 PM
โOct-26-2007 02:39 PM
โOct-23-2007 07:07 AM
โOct-10-2007 06:49 PM
โOct-10-2007 08:17 AM
โOct-01-2007 12:02 PM
Nelly1052 wrote:
1995 Holiday Rambler Navigator with 8.3, 300 hp Cummins. Intermittant problem with turning over but won't start. We're sure its not getting fuel. After it starts, sometimes it stops even going down the road. Checked fuel solinoid. WE think it may be the fuel pump but we don't know if its electric or manual. Not sure where it is. Fuel filters have been replaced. We're on the road but not sure what to do. Owner took it to dealer for problem but worked perfect while there. Anybody familiar with this problem?
โSep-30-2007 05:06 PM
