Bumpyroad wrote:
harold1946 wrote:
All seams and protrusions should be checked at least once a year. I do it twice a year. The ac units have a gasket and require no caulking.
Fiberglass, whether a gelcoat or painted finish, should be waxed or coated with a UV protectant. It will oxidize just as any other finish.
Brite Tek requires only checking and resealing of seams and protrusions.
drive by any marina and note those chunks of fiberglass floating in the water. no waxing, no UV protectant, nothing except perhaps rubbing off algae every once in a while. other than caulking the seams and various things mounted on the roof, nothing else needs to be done.
bumpy
I own one of those boats, and believe me they do oxodize and need protection from UV. Instead of just driving by, walk down and swipe your hand across the gunnel.
I guess it depends on whether one wants to keep it in top shape or let it deteriorate. Its pretty easy to spot the ones that are cared for and the neglected ones, even from a distance.
Go to the search bar and type in gel coat. You may be amazed at the number of posts regarding oxidation and fading of gelcoat.
