AikenRacer
Dec 28, 2013Explorer
Busted leveling jack and stuck!
Pulled into campground in Charleston, SC yesterday. Went to level the motorhome (42' tag). While doing so the mh jerked and the rear end slid. Went out and saw the driver side rear jack (Lippert) lying on the ground and all the fluid in the dirt. The passenger side rear jack is bent outward so that the jack is sticking between the tag and drive axle. Not worried about how it happened but just worried about how to get home. Called the local CW and they cant even look at it until Wed and then they would have to order parts. No other service tech in this area would answer phone or return calls. Tried to retract jacks. Front two do not retract all the way. and the remaining rear sticking out at at 45 degree angle between the axles. Question is: Can I manually retract the front two and maybe the rear? Are the fluid resevoirs independent? All I want to do is get the mh home (3 hours away) on Friday. Any suggestions or ideas? Thanks!
