TwistedGray
Jan 22, 2021Explorer
Sullyd61 wrote:
Hi
I ordered a 28a2017 through the Manassas va. Location . Anyone have any information about getting an inspection in that area . They say they are refurbished in Mesa Az. And then driven to va. Via .hired driver or 1 way rental. Has anyone purchased extended warranty and attempted to use it . Should I expect or ask for anew set of tires . Should batteries be new ? Do they do a complete trans mission fluid change with a new screen.
So you ordered an RV from them without having them answer any of these questions/concerns? You're far braver than others :)
Extended warranty - search the forum. There is already plenty of information on this topic.
Tires - mine came with new or at least newer tires, but you should ask your point of contact at C.A.
Batteries - mine came with a new vehicle battery and not a new coach batter, but you should ask your point of contact at C.A.
Trans fluid change - Mine came serviced, but you should ask your point of contact at C.A.
The common theme is that "your mileage may vary" and you should reach out to the person that you just bought it from rather than the forum. Your experience may vary from my experience which may vary from Bob's experience which may vary...
Edited to add - as you can see from the above reply to your post, your mileage WILL vary!
