Camera
PeoriaKen
Hi folks! I have a 2006 HHR Vacationer that has a camera problem. It's a 3 camera WeldX system. The camera will work fine for a while then all of a sudden go dark in the rear view camera. Sometimes shutting it off and back on and it will come back as if nothing happened and then go out after a while, then when you switch to night driving it will go real dark and it's hard to see tow car. Has anyone had this problem with their rear view camera?
4 REPLIES 4
2chiefsRus
We had a problem with our rear camera when starting out first thing in the morning. It appeared to be caused by the dew running off the back of the coach when we started moving. It went away when we recaulked the rear camera area.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
PeoriaKen
Thanks for a quick guys, running in and out trying to get some much needed yard work done, sorry for the delay.
sdianel_-acct_c
Our problem was the connection to the camera under the dash. Unplugged them and plugged them back in and it works fine. The wires worked loose from vibration. Caused intermittent problem.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
tandkj
WE did sometime past and it was coming from sun light hitting the windshield of the tow and over exposing the camera. We put sun shields on the tow to lower the reflected light.
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast.
08 Camelot Custom build
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
