S-n-L's avatar
S-n-L
Can camp stove be connected to MH propane tank?
Can a camp stove such as a Coleman or Primus, designed to use the one pound propane tanks, be directly connected to the MH propane tank with a hose?
  • of course. You need an "Extend-a-flow" from Marshall brass. Extend-a-stay is a little different, meant to feed the motorhome from an external tank.
    We use one, it works great. We even have an additional "T" so we can feed both our weber Q and our coleman at the same time.
  • You can buy a Tee with check valves built in and hoses that will allow you to use the high pressure from the motor home tank for grills and stove and also provides a connection for an external tank so you don't have to move the motor home to fill it.
    If you do a search on "Extend A Stay" (Marshall Brass) or "Stay Awhile" (Mr Heater as I recall) you can see what they look like.
