toedtoes
Feb 17, 2016Explorer III
Just a note for folks who might read this and have older RVs:
My clipper has an old marine faucet in the bathroom. They no longer make any faucet that fits the existing holes, and as the counter and sink are a single unit, i'd have to replace the entire thing to put in a new faucet.
The kitchen faucet is "standard" kitchen, but the setup is a single hole that sits on a raised square at the back of the sink. Not all "decks" on faucets fit over that square. And you have to use a faucet with a single hole install. I ended up getting a single handle faucet and not using the deck - it sits flush on the sink edge and just fits.
So, if you're rig is older, check it out before buying a new faucet to make sure your choice will actually fit.
I have a pull out and I have no problem with hot water. It's no different than when I had the standard faucet.
38,766 PostsLatest Activity: Jan 10, 2026
