โJan-06-2019 01:31 PM
โJan-14-2019 10:14 AM
wildmanbaker wrote:
No, I don't believe he is. Your comparing a 20 foot pickup, to a 40 foot MH. Do they have the same size chassis, suspensions, and tires? Are they the same wheel base? Like I said, try it yourself and get back to us, please.
โJan-14-2019 08:06 AM
โJan-14-2019 06:19 AM
larry cad wrote:wildmanbaker wrote:bjbear wrote:
Although it is true that a DP with air suspension will compensate for extra weight on the hitch receiver by raising the rear of the coach, that is not the primary purpose of a WDH.
Tell you what, find a scale in your area and give this a try on you MH. Get back to us on what you find out, OK. There are a lot of things that work on paper, but not in real life.
I agree with wildman. Your drawing showing the PICKUP TRUCK changing rear height is totally different than a similar experiment with a DIESEL MOTORHOME where the rear height remains constant. (i.e. doing the same thing as the WDH. I would like to see a set of data from a similar test ON THE SCALES except with your DP. Data is wonderful. Accurate data is even better.
โJan-14-2019 05:42 AM
โJan-14-2019 05:38 AM
The WDH does 2 important jobs.
1) Reduces the load on the rear axle and distributes it between the front axle and the trailer axle(s). Even though the coach may adjust the air to raise the rear of the coach, it does not affect the extra loading on the rear axle. If your tongue weight pushes you over the GAWR or your tire rating, then you should use the WDH.
2) The second purpose (and in my opinion the most important) of the WDH is to reduce the torque loading on the receiver. When the tongue weight exerts a downward force on the ball, it induces a twisting force (torque) on the receiver. The resulting torque has 2 components. First, is the static loading. This is the tongue weight when the rig is not moving. The second is the dynamic loading which is the resulting force on the ball when the vehicle is moving. For example, when the coach goes over a bump, the hitch moves down and then rebounds. This downward movement can exert many times the static loading as the suspension stops the downward movement and rebounds. The WDH counteracts this dynamic loading greatly reducing the torque on the receiver. This is especially critical if using a hitch extension of any kind.
So the bottom line, is that if your tongue weight exceeds the rating on your receiver OR you are using a hitch extension, you should use a WDH. This is true even if you coach air suspension can keep your coach level.
The following diagram illustrates the effect of a WDH.
โJan-13-2019 04:03 PM
Chris Bryant wrote:
I would have a heavier hitch put on the DP, or have a certified welder look at beefing yours up.
โJan-13-2019 12:24 PM
The WDH does 2 important jobs......................
โJan-13-2019 11:17 AM
โJan-13-2019 06:19 AM
โJan-13-2019 01:22 AM
tropical36 wrote:ACDNate wrote:
I'm not sure I understand why, those of you who said so, you don't think a wdh will help.
I've used a wdh with a trailer behind my truck and it significantly lightened the load on the rear end of the truck and put some weight back to the front axle.
Why would it not have the same affect here?
I've often asked the same question, but have never heard from anybody using one and giving the actual weight transfer.
It's gotta do something towards that goal, so the question is how much.
โJan-12-2019 04:22 PM
โJan-12-2019 11:28 AM
โJan-12-2019 10:52 AM
โJan-12-2019 05:18 AM
โJan-11-2019 03:11 PM
