- Grit_dogNavigator
toedtoes wrote:
Nobody is denying you your right to recreate in a big RV. They are simoly trying to stop you from poluting the earth while you do it.
You realize how wacked out you sound, saying that, driving your stinky old dodge hippy van?
No wonder how this c rap actually happens down there… - TreefrogExplorerToedtoes, question: if a 2000 diesel RV doesn't pass emission test doesn't the rule require the motor to be in compliance to be registered in 2024?
- toedtoesExplorer III
N6WT wrote:
Am I reading it correctly that this only applies to 2010 and older?
No. The last links provided are for a different regulation that does NOT affect personal use motorhomes.
The Heavy Duty Inspection and Maintentance Program affects all diesel powered motorhomes of more than 14,000 gvwr. It is simply a once a year inspection of the motorhome's emissions control system. And that inspection can be done remotely via the motorhome's OBD. - toedtoesExplorer III
N6WT wrote:
Apparently, there is a way to exclude your DP from the new reporting regulations.
I found this YT vid which had this link in it.
https://www.youtube.com/watch?v=D7QKCDmCjfo
https://air.arb.ca.gov/edvr
I have not done it yet so I dont know if it works.
Some hoops to jump through, but it looks like it will fix the mess for RVs. I hope?
This is not for the Heavy Duty Inspection and Maintenance Program being discussed in this thread.
This is for the Truck and Bus Regulation that requires trucks and busses over 14,000 gvwr (NOT personal use motorhomes) to replace or retrofit their engines to 2010 or later emissions standards (retrofit with filters or replace with 2010 or later model engines). The links you provide discuss how to claim an exemption to this requirement. P.S. this regulation has been in effect for around 10 years and the retrofits/replacements are to be fully complete by January 1, 2023, so this is old news.
The Heavy Duty Inspection and Maintenance Program that is the subject of this thread is simply ensuring that the vehicles' emissions control systems are in proper working order. There is NO requirement to retrofit or replace engines. There is no exemption process. - N6WTExplorerAm I reading it correctly that this only applies to 2010 and older?
- OrcadrvrExplorer
oldave wrote:
Apparently, none of us actually read the document.
I decided to read it and found this.
(The program also will apply to California-registered motorhomes, which will be required to undergo compliance testing once annually)
Not 4 times, only once a yr, Right?
Certainly better than four times a year, but the question remains:
What other vehicles in California require annual, as opposed to bi annual inspection.
As I stated before, it is pure harassment considering the limited miles these vehicles are usually driven. - N6WTExplorerApparently, there is a way to exclude your DP from the new reporting regulations.
Another link:
http://ww2.arb.ca.gov/sites/default/files/truckstop/azregs/edvr.html oldave wrote:
So those potential visitors registered in their home state will not get any hassle at all.
Much more exciting to make all this other stuff up.- oldaveExplorerApparently, none of us actually read the document.
Not 4 times, only once a yr, Right? - 4x4vanExplorer III
CKNSLS wrote:
Sadly, it has gone beyond the idea of cleaning up the air and instead is about nothing more than money and forced lifestyle change. I, too, grew up here in CA, and still live here. I agree that the air is cleaner than it's ever been; I remember the smog alerts in the 70s, and it being difficult to breathe as a kid. However, CA's goal is to eliminate ALL internal combustion engines, and as soon as possible. And if they can't convince you to give them up voluntarily, they will gladly make it so that you can no longer afford to use them. 2 things prove that air quality is no longer the goal:
For those who didn't "live it"-
I grew up on Southern California in the 60's and 70's. In the 60's we used to go to my Grandma's house in the San Gabriel Valley. The San Gabriel Mountains were 20 miles away as the crow flies. In the summer time I used to play outside and the air was so filthy I couldn't see those mountains just 20 miles away and my throat would hurt severely. Fast forward to today-the population has DOUBLED since I grew up there and there are more vehicles registered there than any where else in the Country. The air is cleaner than it's EVER BEEN. All because of CARB mandates-that were so successful by the way they were adopted by several other states. I have since retired and moved out of state-taking my massive equity with me. Yea say what you will but quite frankly you cannot by any stretch argue with the results. So yea-camp elsewhere.
1. A few years ago, my sister-in-law's car wouldn't pass smog. Why? Because of a "misfire" that the computer picked up. Now keep in mind, that this "misfire" was so slight that it was completely un-noticeable while driving/idling, AND the car's tailpipe emissions were within acceptable levels. But she was still forced to spend several $100 dollars chasing down a non-problem before DMV would renew her registration.
2. Decades ago, in addition to the cost of the smog check, we also had to pay $8.25 for the "smog certificate". That hard copy printout had to be mailed (or taken in) to the DMV along with your registration in order to renew. Well, about 30 years ago, they did away with that paper certificate, and it is now transmitted online to DMV automatically. But guess what? We STILL pay an additional $8.25 "certificate" fee when getting our vehicles smogged!
CARB is out of control and accountable to no one. The agency should be disbanded and the people at the top should be jailed for stealing more money from CA residents than any other organization in the state's history. Cars, RVs, lawn equipment, small generators...where does it end?
About Motorhome Group
38,709 PostsLatest Activity: Mar 09, 2025
