Hotwheelbill's avatar
Hotwheelbill
CC problems.
Hello again all. I took a short trip to Fork Clinch yesterday and found that my CC is not working right. When I push the SET button (also the accele button) all it will do is accelerate. I have to press off to stop it from accelerating. Any ideas as to where to begin? How do I get to switch on steering wheel.
1998 Georgie boy diesel.
  • Look up. www.thorssell.net There is a wiring and parts diagram and how to test. With a volt/ ohm meter and a test light all the switches on the steering wheel can be tested. There are tests for the servo as well as the brake cancelling system.
    I had to change the servo and the vehicle speed sensor to get mine to work.
    Good luck, Doug
  • Ava wrote:
    Is that a Ford steering wheel with the controls on the wheel? I have spent hours working on mine and there some easy checks to make if it is a Ford system.
    Yes, it looks like a ford wheel.
  • Is that a Ford steering wheel with the controls on the wheel? I have spent hours working on mine and there some easy checks to make if it is a Ford system.
  • We need more information:
    What chassis?
    What engine?
    Is this an external cruise such as made by Bendix in the 1990's or is it electronic?
