lfeather
Sep 23, 2014Explorer
gatorcq wrote:
The state of charge is depended on a few items.
1) how the internal shunt is connected
2) how many cycles (charge/discharge) you completed
3) whether or not your alternator is involved in the setup
4) whether or not solar is installed
5) the correct setup - better in the auto mode for battery capacity
6) fuel gauge cut out seting
Battery Capacity refers to the battery's reserve capacity in amp-hours. The RC7 approximates the battery state-of-charge (SOC) and run-time then estimates the battery capacity (Auto) over several charge/discharge cycles. However, setting the capacity manually assures a more accurate initial SOC and run-time calculations. The default setting is Auto.
The Fuel gauge Cutout menu sets the battery voltage zero percent state of charge (0% SOC) with no load. This is the point at which the battery has zero reserve amp-hours remaining. The Fuel gauge meter uses this number to determine the 0% battery state-of-charge voltage. The default is 9.5 VDC.
"However, setting the capacity manually assures a more accurate initial SOC and run-time calculations"
Interesting. Maybe I'll try the manual capacity setting. Thanks.
38,705 PostsLatest Activity: Jan 21, 2025
