dougrainer
Oct 04, 2022Nomad
Horsedoc wrote:
Couple of questions come to mind. Unless the bad bearings was super heating the wheel and thus the tire, why was it 'seconds' from blowing and causing the 'catastrophic' accident? Should he not have heard and or felt the bearing going out long before it reached the point of heating enough to cause the tire to blow?
Is the description of the incident being enhanced as it was being related to the OP from the driver? Not sure why the MH would need to be put on a jack just to change the bearing or the front spindle. Confusing post in the details
You do NOT understand why the MH would have to be on a Jack to "just change the bearing or Spindle"???? You should not be posting about things you are not knowledgeable of. I bet you can change your Auto tires when flat without a jack also:B
LAST, funny the OP has not come back. Sounds like a troll, disparaging Ford. Doug
