โSep-15-2020 01:08 PM
โOct-19-2020 04:02 PM
falconbrother wrote:
We went from a motorhome to a travel trailer. Couldn't be happier. Much simpler to own. Not that a motorhome is a bad thing. It's way more maintenance. Would I get a motorhome again? Only if our lives drastically changed. For what we do the travel trailer is far superior. That is, we hook up, go to our destination, stay a few days. Then maybe move to another destination, stay a few days, then head home. If we were going to be traversing the US a motorhome would be the better choice.
It was nice to have all the amenities of home while rolling down the interstate. I do miss the generator, microwave and bathroom. Of course we have bathroom now but, we have to pull over. The front of the motorhome, where the drivers and passenger seats are is mostly wasted space when camping. In the travel trailer we use all the space, and we have a big slideout, which is solid gold. We had an older class A with the huge windshield. I would freeze up there while driving in the winter. The heat would keep the house warm enough but, it was cold in the very front. Two oil changes, big bucks for tires, insurance, other repairs, etc.. Motorhomes cost way more to own. But, can be worth it. It's nice to get to the campground in terrible weather and not have to get out in it till the morning. We pulled into a campground, in the dark, in East Tennessee in a driving rain. I disconnected the toad, backed in the motorhome and called it a night. The trailer requires more work.
There is no perfect. I'd say that if you plan to do a lot of moving and driving get the motorhome. If you plan to get to your destination and spend time there, get the travel trailer. Towing isn't bad at all as long as you have enough tow vehicle and the hitch is set up correctly. In fact, towing the travel trailer is less stressful for me than driving the motorhome and pulling the toad. I don't really feel the trailer back there 95% of the time, and out trailer is 30 feet long. However, backing a motorhome into a tight space is easy. I never had an issue with that, in the dark, and rain. Backing a 30 foot trailer into a tight spot is more difficult (for me anyway).
Either way you'll be OK. I met some kind folks from Canada that were hauling a travel trailer all over the US. My sister's in-laws pulled a travel trailer from the West coast the the East coast and North and South about every year (with a Dodge 2500). If I were traveling that much I'd rather have a motorhome. They preferred the trailer.
โOct-19-2020 11:56 AM
โOct-19-2020 06:21 AM
LeslieCovin1974 wrote:The dilemma become easier to answer if you know what size you want and how you plan to camp. If you want something short 23-25 ft a C would be fine 26 ft and longer I would look at an A. Also what is important to how you camp. For me outside storage and FW capacity is more important to having a outside TV or sound system. CCC is also very important to me not so much for others. Do you spend a week or more at a CG and want to explore the surrounding area you may need a tow car. If you are more of a traveler and stay a night or two at each CG a 24 ft C without a tow car may work fine. Do you plan to stay at private CG's with FHU's or NP's, NFS, or SP CG's? If private FW and battery power is a non issue. How many people will you travel with? Is performance on hills out west important? Gas C's and A's have the same engines at any length. So short MH's will have better performance than longer ones because of a higher HP/weight ratio. Also age and physical limitations are also something to consider. TT hook ups, backing up, messing with a portable generator become more of a hassle for older folks. Hooking and unhooking a tow car also becomes a hassle to some older people with shoulder or back problems. If you can answer some of these questions the type of MH that best suits your requirements will become much clearer.irishtom29 wrote:
Larger Ford based Cs, 30 feet and longer, often have lousy payload, I saw some with under 1000 pounds.
it's an eternal dilemma, which is better?
โOct-19-2020 04:57 AM
โOct-18-2020 10:01 PM
โOct-17-2020 07:59 PM
โOct-15-2020 07:55 PM
surgtech56 wrote:
We have been thinking about getting a Class C vs another TT. Here in Michigan Insurance is around $300-$400 a month for a Class C. One of us thinks a Class C is the one to go and I think a Class C might be more of a headache. We would be buying used, probably in the $40K price point(there abouts). Not sure if we want to tow a vehicle.
Those of you with a Class C can you give me some pros and cons, any information.
I know this is pretty vague, but trying to figure out if this is the way to go. Thank you in advance
โOct-01-2020 02:58 PM
pnichols wrote:Atlee wrote:pnichols wrote:
I wonder if an F450 is a completely different animal from an E450 chassis?
A F450 chassis is definitely a completely different animal than an E450.
How so? Why isn't a "400 series" chassis a "400 series" chassis, regardless of it's configuration? What kind of games is Ford playing, anyway?
I bought a small Class C MH on an optional E450 chassis because I wanted a 400 series chassis under the coach even though it wasn't required raw-weight-wise ... but in a van configuration for minimum overall length and maximum compactness.
โOct-01-2020 11:46 AM
ron.dittmer wrote:
When it comes to any kind of motor home, there is a delicate balance between "excess weight capability" and "quality of ride" which sometimes can influence "handling". Generally speaking, the more excess weight capability, the more harsh the ride will be, and the better it will handle. Less excess capability makes a softer ride, but might handle worse. An empty heavy duty van or pick-up truck, the harsh ride exists too, but you are not driving a house. There is a huge difference shaking up a house and it's contents, versus an empty heavy duty van or pickup.
โOct-01-2020 11:24 AM
โOct-01-2020 03:31 AM
โSep-30-2020 06:22 PM
โSep-30-2020 09:45 AM
โSep-29-2020 08:19 PM
Atlee wrote:
Of course the F550 chassis is a completely different animal from an E-450 chassis.
I wish smaller class C's were made on smaller truck chassis rather than on the cut out van chassis.kwplot34 wrote:irishtom29 wrote:
That's not entirely correct anymore. Check out the Thor Omni/Magnitude on the F550 chassis.
