- pnicholsExplorer II
memtb wrote:
Autumn Snowbird, If you will be doing any boondocking, fresh water tank capacity is of much importance. I hate (well almost) to keep beating the Bigfoot drum, but... Bigfoot also had the highest capacity fresh tank of the class c’s ( that we researched)!
For comparison purposes, here's the specs on typical 2004 Bigfoot (click on "Specs") Class C motorhomes and current Lazy Daze Class C motorhomes. Note that Lazy Daze tank capacities are right in the ballpark with those of Bigfoot:
http://www.rvweb.com/guides/manufacturers/bigfoot_industries_inc./models/2004_3000_series_motorhome-1083961402961
http://www.lazydaze.com/FEATURES.PDF
(FWIW, our Winnebago Itasca 24 foot Class C capacites are FW=39 gal, GW=29 gal, and BW=39 gal.) - rockhillmanorExplorerFor the front an outside bonnet, inside windshield sunshade, and blanket to cover cab opening being sure it goes down past the coach floor to cover all the way to bottom of captains chairs in cab.
pianotuna wrote:
Hi Rockhillmanor,
I had Insulbright covers made for all windows, skylights and vents and for a cab separator. Storage becomes an issue pretty quickly.
I found a better way to help insulate side window s in the coach. Van size windshield sun shades just happen to fit perfectly behind the day night shades!! No Velcro no drilling holes. Just slip them behind the shades. And boy do they make a difference keeping the cold out and also the heat out in summer. If window is smaller you just fold one or two panels up.
Best part, the fold up flat. I had all five of mine folded and slipped behind driver's seat. No added storage room needed. - memtbExplorerAutumn Snowbird, If you will be doing any boondocking, fresh water tank capacity is of much importance. I hate (well almost) to keep beating the Bigfoot drum, but... Bigfoot also had the highest capacity fresh tank of the class c’s ( that we researched)!
If you can spend some time on YouTube, you can learn a great deal about many of the class c’s available! - memtbExplorer
ctilsie242 wrote:
Triple E was a good class "C" maker, but they are history as of now, as the company is focusing on the (arguably) more lucrative B market.
If I were going for a cold weather "C", I'd look at a Phoenix Cruiser or Nexus RV. Then, I'd also see if they could add custom skirting, to reduce heat loss under the rig.
From my class "C" experience, I would see about making a foldable divider made with a Coroplast core, Reflectix on the cab side, and a thick blanket on the other side, which would go between the cab and the rest of the coach. This not just adds significant insulation, but helps deaden noise. Done right, it is easily moved out of the way, so the cab can be used for storage space.
Not sure about Nexus, but Phoenix did not have enclosed tanks ( I called). Can’t remember exactly, but, I believe that it was “on me” to enclose. Way much easier if designed that way originally!
Trying to keep “ non-enclosed” tanks warm in “cold” weather, is kinda like trying to heat your home with the doors and windows open! - RambleOnNWExplorer IIHeated enclosed basements require far less energy to keep the tanks warm. Our rig has single pane windows but we section off the cab and have fitted reflectix panels for all windows that we keep in a roll under the bed. Have only dry camped to 20F with 20 MPH wind with no issues. Went colder on electricity and added a 100W clip lamp to enclosed wet bay which kept things warm.
Here is a current ad for a 2011 28 foot Triple E Regency 28GT which is the non-cabover version of what we were looking for. $73K:
https://www.rvtrader.com/listing/2011-Triple-E-REGENCY-28GT-5000724336
Similar layout to our dual-slide Jayco without the cab-over. - pnicholsExplorer II
pianotuna wrote:
Hi Phil,
In truly cold weather heating pads cannot keep up with the heat loss. Enclosed tanks are a far better solution. Even so I find I need 250 watts of heat--and I used to use 600 watts.
Don,
For extreme cold, just have double pads installed on the bottom side of each tank. There's plenty of room on each tank bottom for two pads. - pianotunaNomad IIIHi Phil,
In truly cold weather heating pads can not keep up with the heat loss. Enclosed tanks are a far better solution. Even so I find I need 250 watts of heat--and I used to use 600 watts.pnichols wrote:
heating pads onto any tanks exposed to the outside air temperatures. With heating pads on your tanks, all RV furnace air can be used to keep the inside of the coach warm instead of some of it being used to keep warmth around tanks. - pnicholsExplorer IIMike (the OP),
I assume that during cold weather camping you're going to be on hookups or, if cold weather dry camping have a pretty good sized RV battery system and a generator to keep them charged?
If so just look for an RV - or have installed after you buy an RV - 12 volt DC powered (they are available as 120 volt AC powered or 12 volt DC powered) heating pads onto any tanks exposed to the outside air temperatures. With heating pads on your tanks, all RV furnace air can be used to keep the inside of the coach warm instead of some of it being used to keep warmth around tanks. The reason I say have "12 volt DC" pads installed is so you can use them during hookup or non-hookup camping - or when driving down the road without having to run the coach furnace ... which makes for an overall more flexible tank heating system.
The slightly warmed water from the tanks lying against the tank sides of the tank emptying valves keeps the emptying valves from freezing so you can operate the valves for tank emptying during cold weather.
To my thinking, tank heating pads is a superior way to keep your tanks' contents from freezing - over wasting precious coach furnace hot air and propane to keep your tanks from freezing. Besides, electricity is easier to find or make than propane is during either cold or hot weather. Why keep a whole volume around tanks warm with heated air when all that is necessary is to keep the liquid inside from freezing by merely having an area on the tank bottom kept warm via a flat, glued on, tough rubber material, built-in thermostatically controlled ... 12 volt electrical heating pad? - ctilsie242Explorer IITriple E was a good class "C" maker, but they are history as of now, as the company is focusing on the (arguably) more lucrative B market.
About Motorhome Group
38,707 PostsLatest Activity: Jan 05, 2014
