Coach Batteries
rickvikki
Hello Everyone:
Just a question about replacing coach batteries. We have a 40 ft DP Tiffen Phaeton (2006) and need to replace one of our 4 6volt coach batteries. Can we replace just the one or do we need to replace all four?
Thanks, Rick and Vikki
Rick and Vikki Landry
Ottawa, Canada
Tiffen Phaeton 2006 (40 ft.)
12 REPLIES 12
ArchHoagland
Vulcan Rider wrote:
ArchHoagland wrote:
I would buy a hydrometer, about $10, and test all four batteries.
I'd make my decision based on that.
A random specific gravity reading is meaningless.
For it to be meaningful, you need to (try to) individually charge each battery fully and then take a reading.
And of course if you already have AGMs getting that sample of fluid is gonna be kind of tough.
๐Ÿ™‚
You are correct. The hydrometers come with instructions so I was not going into great detail.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
HPYHILM
I had the same problem. Took my coach to a local golf cart dealer and the tested and replaced the trojan battery with a similar year one that was used to match the others, they where good for 5 more years. Only charged me 50 bucks for the used and that included installation.
Hpyhilm
NW Washington
2008 Monaco Knight 38PDQ
Vulcan_Rider
๐Ÿ™‚
ArchHoagland
US Gear Brakes
fivejackie
All of the above are true. Replace all 4 of them.
Don and Jackie
2115 Hurricane 27K
2113 Redhawk
1992 Pace Arrow
Mr_Mark1
As others have mentioned, depending on age, I would consider replacing them all.
You might also consider replacing them with AGM batteries as they are much cleaner and don't sulfate like regular wet-cell batteries and you don't have to had distilled water. AGM's are more expensive so you will have to weigh the convenience.
Safe travels,
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
Vulcan_Rider
Beverley&Ken wrote:
How old are the batteries? If there 5 or 6 yrs old and one has failed, the others may not be far behind, as others have said replace all. If the batteries are only 1 yr old, I think that would be a different scenario.
Ken
This is the best answer.
But others who said "Replace them all" are not far behind.
Ed_Gee
rickvikki wrote:
Hello Everyone:
If you value the reliability and longevity of your 12VDC system you should replace all four batteries.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Beverley_Ken
I'm not a battery expert, but one thing to think about, How old are the batteries? If there 5 or 6 yrs old and one has failed, the others may not be far behind, as others have said replace all. If the batteries are only 1 yr old, I think that would be a different scenario.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Rabbi
Rick and Vikki,
My understanding would be that you have a total of 4 6 volt batteries 2 each connected in series (for 12 volts) and the two 12 volt groups connected in parallel giving the total 12 volt amperage to the coach. Assuming the batteries are all the same age and one has failed due to age, sulfation, ect., conventional wisdom would have you replace them all. That said, and there is some controversy here, but if you are confident in the condition of the other batteries, you can,technically replace just two--the known bad one and its 6 volt mate in that 12 volt series. Many lab and field test have demonstrated over the years that the charging system can compensate for differences in batteries wired in parallel (such as batteries of different amp ratings and to some extent ages) but not when wired in series. I'm sure I may get some push back on this, and rightly so, because as a practical matter batteries are generally replaced all at one time in a given bank. However, that may not be always necessary if they were not purchased/or been in use, the same period of time.But clearly only in parallel wiring thus the minimum of 2. Kind regards.
dons2346
A bank of batteries will be only as good as the worst one of the bunch
bdpreece
Can you? Yes. Should you NO. If one is bad the others will soon follow also the batteries will all mimic the weakest one. Bite the bullet and replace them all.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
