KristinU's avatar
KristinU
Cold Climate Folks: how often to run your C in the winter?
I know, I know, the easy answer is to go south to warmer climes!!! Future plans call for that for sure, but for the next decade we're stuck at work and beholden to the school calendar.
So this will be our first winter with a driveable, and I understand that it is a good idea to run it every so often when in storage (and run the genny with a load on it while we are at it). It will go unused for 4 months: December, January, February, and March.
So do you guys do this religiously? Once a month? Just run it or drive it around a bit? How long?
We were planning on covering it for the winter since it will be stored outside and we've had good results with covering our previous towables. However I'm not sure how that will play into the equation if you guys recommend actually driving. If we're just running it, I would think we can fold back the cover enough to allow for front and exhaust ventilation - would you agree?
Anything else we should keep in mind as we get ready for winter? We do plan on adding Sta-bil and topping off the tank. Anything else?
Thanks in advance for any advice!
