Your system (2005)
ENERGY MANAGEMENT SYSTEM -
SO AMP
Intellitec's Smart Energy Management System -
50 AMP (Smart EMS) is designed to be used in
RV s equipped with 50 AMP electrical service.
The system senses when the coach is connected
to a 50 AMP service or operating from the generator and allows simultaneous operations of all
the 120 volt loads. When 50 AMP service is not
available and the coach is connected to a smaller
electrical service, such as 30 or 20 AMP, the system automatically takes control of the loads to
practically eliminate circuit breaker tripping. It
constantly monitors the total amount of current
drawn in the RV and controls the loads, as necessary, to keep the total current to a value less than,
or equal to, the available power service.
There is no programming necessary and the unit
will work with any load within the circuit
breaker limits. The Smart EMS automatically
"learns" the amount of current drawn by each of
the controlled loads as it turns them on and off.
In this way, it automatically adapts to differing
loads or loads whose current changes with line
voltage or temperature.
Features:
• Limits total current to 30 AMPs.
• Minimizes circuit breaker tripping when
connected to 20, or 30 AMP service.
• Eliminates manual appliance select
switches.
• Senses current of owner added loads.
• Owner selectable 20 AMP operation from
remote panel.
• Protects air conditioners with two minute
restart delay.
• "Learns" controlled appliance current draw
Click this link for an in depth explanation.
https://intellitec.com/wp-content/uploads/2022/07/53-00894-600-1.pdf
