lucytravel12
Oct 03, 2016Explorer
Composting Toilet
Do any of you have a composting toilet in your B? If so, how do you like it? What brand do you have? Did you install it yourself, or was it a professional install?
Islandman wrote:
Ic0338 wrote "These guy's like it for RV... I believe ........ only needs a little 12volt fan power... "
I learned something new, the composting part sounds interesting, the liquid waste would go into a smaller black tank I suppose. Don't know about duming the compost portion into the lake after it's become compost though.
Islandman wrote:Composting toilet, not incinerator toilet. No help at all.
From what I've heard, composting toilets aren't really meant for RV use, the one's that I've been acquainted with were in campgrounds where electricity was available as the system depends on heat to convert the disposal into ashes. Maybe there are some newer systems around that I haven't heard of yet. Might be an expensive conversion and depends on some sort of heat source (solar, battery, etc).
