SGTJOE's avatar
SGTJOE
Dec 07, 2019
Continental Tires PSI rising 20
I recently bought Continental 255/70R 22.5's for my Tradewinds, it has always ran Michelins but none were available. I'm traveling from Southern Utah to Southern Arizona and am running 100psi in all 6 tires. I have a TST TPMS that I've used since TST first started that monitors each tires temperature and psi. The 100psi goes up to 120psi going down the road at 65mph. Outside Temps were running high 50's/60's. The Michelins never went up this much. I don't think they ever went more then 6-8 psi, even in 108 outside temperatures. My Honda CRV tow vehicle only gains 2 to 4 psi and these are with Continentals also. My old Michelins were 14 ply and the new Continentals are 16 ply, could this be the cause???
Is there anyone on here who is running the same size Continentals with a Tire Pressure Monitor System that monitors PSI and Tire Temps?? One more thing my Tire temperatures were running a few degrees above the outside temps. The tires were not hot at all, only problem is the 20 degree rise of the psi
