Jul-30-2020 02:23 PM
Aug-01-2020 08:19 AM
Jul-31-2020 06:27 PM
enblethen wrote:
Converter is commonly located in void behind the power distribution panel.
Majority of gas Pace Arrows have a battery control center under the hood. It it is a paralleled set of circuit breakers that send power to the 12 volt power distribution center.
There should be two battery disconnects. One for chassis battery and one for the coach batteries,
In the 12 volt power distribution panel is a main BAT fuse. Check it for power.
The converter could have reverse polarity fuses on the end where the large 12 volt cables come out.
The converter is fed from the 120 volt AC power distribution panel. Reset all circuit breakers. Turn them all off by shutting them off applying light pressure toward off. Turn on main circuit breaker followed by branch breakers one at a time.
Model should be M-35K, correct?
Check the main 12 volt fuse for power. If converter is operating properly, it should be putting out around 13 volts.
Jul-31-2020 08:47 AM
Jul-30-2020 05:44 PM
Jul-30-2020 04:39 PM
