Transfer switch does control the flow, sort of, but only of 120 volts it has two inputs and one output.
Inputs are: Shore power, and Generator power.. Depending on the transfer switch it has two or 3 states
1(Optional) OFF
2:(Resting state on mine) SHORE
3: (Generator active) GENERATOR
NOTE: TURN OFF EVERYTHING BEFORE STARTING/STOPPING generator then turn it back on after generator starts (or 3 minutes later if stopping).
Converter: COnverters make 12 volts out of 120 volts (you know that) but they are often part of the power distribution panel, IF this is the case you will have a panel that has both 120 volt breakers and 12 volt fuses behind the same door... (However this type of panel is not a 100% That is where it is).
The second type is a Stand alone (I have one of those) can be mounted anywhere, in my case as far from the batteries as possible (Or the worst possible place to put it, take your pick, both apply).
The third is an in-line Inverter/converter combo unit (got one of those too)
This too is a "Stand alone" unit but usually closer to the batteries.
