SPRING_STREET's avatar
May 04, 2014
Could it be my fresh water pump ??
Getting ready to leave campground and am having trouble with fresh water back flowing through my fill hose. All weekend have been using campground water direct, with my water pump off, as usual.When we were getting ready to disconnect and store hose, for the ride home, i switched the water pump on from the outside switch and fresh water started to come out the hose. Turn the water pump off and the water stops. What would make this water back flow from the fresh water tank?? I can hear the water pump but doesn't sound as loud as usual, could this be my problem ?? Thanks Dave!
  • wa8yxm's avatar
    wa8yxm
    YOu should have a male hose plug in that fitting any time a hose is not in the fitting,, Just for safety.
  • Thanks for the suggestions. We got home hooked up the water, then disconnected and everything worked as it should. I assume the one way valve was stuck. I will purchase a male hose plug just for a quick temporary fix if it should happen again!
  • The quick temporary fix is an inline hose shut off valve available at pretty much any hardware store or Walmart. Even one of those handy 'Y' adapters with dual valves will do the job. No need for any fancy fittings.
  • Just slightly off topic but we always fill the FW tank and use the pump for our RV use. It takes about 10 minutes to fill the FW tank and the sound of the pump in the middle of the night indicates trouble that can't be heard connected to CG water. Leaving the rig for awhile requires flipping one switch to shut off the pump.
  • wa8yxm's avatar
    wa8yxm
    First: When you say "Backflowing through your fill hose" do you mean "Backflowing through the fresh water inlet?
    No, that is not the fault of the water pump.. In fact it's no where near the water pump.
    The inlet, be it a straight inlet like I have or a Sure Flo regulator inlet, has a check valve in it.. This check valve has failed.
    Now: Some folks warn that "If you do this you can destroy the valve and it will never work".. I think they are wrong but consider this... it is not working now, so if you make it not work, Well nothing has changed. (Which by the way is the origin of the myth,, It's not working now, You can't make it worse).
    Remove the screen washer (Pump off) NOTE you WILL get wet in this procedure
    Under the washer you should see the actual inlet and there should be a 3 or 4 "Arms" holding a small circle (like a washer) with a button in the middle.
    Turn on pump, water will flow
    Push button with pencil eraser or short rod
    Release
    you may need to do this 3 or 4 times
    If no success by 5th try, TEMP solution is to screw in a plug, You can get plugs at most RV stores including some campground stores or you can get a standard male garden hose adapter (3/4" to hose or 1/2" to hose) and a matching pipe cap at any hardware store.
    Long term solution: Replace inlet.. USUALLY this is a very easy job.. If the inlet is mounted in something with screws holding it in remove the screws,, PULL the inlet and benzel toward you gently,,, Hoses and pipes should have enough give, Unscrew by holding nut on back where plumging hooks to inlet (or holding elbow) and turning inlet counterclockwise.. Take to RV store, get replacement, replacement is reverse of removal.
    Alternate repair: (I rather like this version but..) Most hardware stores will have a garden hose size "Spring check" valve (3-4 inch you may need brass adapters) screw it into the outlet, job done.. You may want a short strain relief hose to make hookup easier.. Or a quick disconnect system.
  • Same here, I carry a male hose plug, just in case this happens (again). Very annoying when the pump cycles for a couple of seconds, every 5-7 minutes when not hooked up.
  • Beverley&Ken wrote:
    It's the one-way valve at freshwater inlet. With the hose off, (and pump off) flick the little plastic tip in the inlet, It may reseat properly, it may not. $10 part and very easy to replace.
    Beverley&Ken
    x2.
  • It's the one-way valve at freshwater inlet. With the hose off, (and pump off) flick the little plastic tip in the inlet, It may reseat properly, it may not. $10 part and very easy to replace.
    Beverley&Ken
