I have a Holiday Rambler 2004 DP, Dash ac worked great leaving south of Houston at 1 pm on Tuesday. Got down the road maybe 30-40 miles it starts to cool less and the further I went the less it cools.
Is there a high pressure switch in the system because when I stopped and let it idle for 5 minutes it went back to cooling great. I keep a small thermometer in the vent so I can track what temps are when running. When I start out it is down in the green, about 50 degrees. I have had problems with the system in the past and have learned you don't overfill with 134a because it will not cool at all. I am thinking I still have to much coolant and the hotter it gets the higher the pressure and then the compressor is shutting down. Any of guys had to deal with this problem?
Thanks
