BobbyclassA's avatar
BobbyclassA
Dash and vaccum hoses?
Hi, I'm new here and just got a 2000 winnebago Suncruiser with the ford V10 in it. Just a few minor things going on with it. First the vents didn't work in the dash no air flow. Found that the white hose in the dash came apart. I fixed that but still don't have much air pushing through the vents. Looking around I found this what looks like a vacuum tube on the valve cover on the driverside front. Does a vacuum line go on that and where does it go to? Second is the Onan 5000 gen set. It will turn over and start but won't keep running. IF you hold down the start switch it will run once you let go it stops. I did the oil thing and that did not help so whats next? Thanks for any help:? Sorry no pic
