Mrj1981's avatar
Mrj1981
Dash gauges
My 2008 Monaco Cayman xl.
When I switch the igniti noon on the gauges should sweep
They stopped doing this
And the diesel gauge is sparodic
When I fill up it takes. Five minutes to get to full reading
Amy help with knowledge would help
I called technical assistance at Monaco
You would think I as talking in gibberish
Oh well. Let's try here
Martin
  • X2 but I,d start at the frame ground of the rv take the neg post of battery follow it to the frame take off clean to bare metal rebolt to frame .clean up or replace ground cable. and clean battery post.
  • Typically, these types of issues are ground related. You can pull the panel at the top of the dash and access the back of the instruments. Find the ground on the instrument cluster and temporarily clip on an additional ground.
    All of the instruments on your coach will have threaded rods with nuts holding the wiring on, make sure the nuts are all tight.
