jeffo's avatar
jeffo
Diameter of TST507 Sensors
What is the diameter of the tst507 flow thru sensors? I have extenders on the rear but not on the front and I would rather not add them if not needed. I have read where you can remove the theft protection device an manually install them without the wrench and that should make them smaller.
Thanks
Jeff
  • The are smaller when you remove the antitheft part. I do that on the rear out side tires so I can easily remove them.
  • I double checked. The locking case is 1.07" (about an 1 1/8). The sensor without the lock cover is .95" (about 1").
  • DSDP Don wrote:
    Jeff.....I had a concern about the size because I didn't like the look, especially on the front wheels. I was also concerned how far they would stick out. I bought a set and found that the outer theft protection really doesn't provide much protection. You can easily remove them with pliers by holding the back of them.
    To answer your question, the diameter without the protective cover is 1". The length is just a smidge over an inch long.
    Hey Don...Isn't the outside diameter approx. 1" WITH the protective cover, and maybe about 3/4" without?
    My rig is in storage so I can't see mine see right now, just going from memory.
  • Jeff.....I had a concern about the size because I didn't like the look, especially on the front wheels. I was also concerned how far they would stick out. I bought a set and found that the outer theft protection really doesn't provide much protection. You can easily remove them with pliers by holding the back of them.
